The windowed side panel on my h440 wont come off .-. The top screw comes out fine but the bottom thumb screw is stuck, I tried to loosen it but nothing works, I fear its stripped. What am I to do!!!
Intel i5 4690k | NZXT Kraken x61 | MSI z97 Gaming 5 | MSI GTX 970 EVGA Supernova G2 750 G-Skill Ripjaws 16GB 2133mhz [2x8] | Western Digital Caviar Blue 1TB HDD Samsung 850 EVO Series 250GB SSD NZXT H440 [black and Red]
Saving for a Dream rig :)
https://linustechtips.com/topic/452846-h440-side-panel-stuck/
try putting the head of the screwdriver in to the screw with a rubberband between them it can help grip the screw
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/452846-h440-side-panel-stuck/#findComment-6073475
Did you try to unscrew it with a screwdriver , or just by hand ?
The Subwoofer
Ryzen 7 1700  /// Noctua NH-L9X65 /// Noctua NF-P14s Redux 1200PWM
ASRock Fatal1ty X370 Gaming-ITX/ac /// 16GB DDR4 G.Skill TridentZ 3066Mhz
Zotac GTX1080 Mini
EVGA Supernova G3 650W
Samsung 960EVO 250GB + WD Blue 2TB
https://linustechtips.com/topic/452846-h440-side-panel-stuck/#findComment-6073476
Pull back when loosening the screw once loose just yank on the side panel to slide it back. It should come off fairly easy.
https://linustechtips.com/topic/452846-h440-side-panel-stuck/#findComment-6073480
My hero :P
https://linustechtips.com/topic/452846-h440-side-panel-stuck/#findComment-6073502
