Memory speed problems
Solved by leipero,
Phenom II CPU's don't support memory frequencies above 1333MHz for DDR3. That is your problem.
On the other hand, it isn't the problem, since difference is non existent for general use (or anything for that matter), and stability loss is obvious , even on CPU's that do support higher freq. RAM.
Bottom line, keep it at 1333MHz, 9-9-9-24 timings and 1.5v (auto).
Featured Topics
alexfic ·
Posted in New Builds and Planning3 -
1
BryanOttawaDetroit ·
Posted in General Discussion1 -
2
2
GoStormPlays ·
Posted in WHALE LAN1 -
GoStormPlays ·
Posted in General Discussion6 -
9
jordan_wills ·
Posted in New Builds and Planning2 -
5
