Slide Show Help
Solved by Guest,
I've got it. The part that would take the longest is resizing the pics. They're all very large. Tips?
Do you know how to create the slide show with them?
Just go into insert, select Photo Album, Insert from File/Disk, select all the photos, set the layout, then click create. Might take a few minutes depending on how many photos you have, but that's how I do it with MS PP at least.
You'll probably have white borders, so there may be a better way which just uses the images as the slides...
