What's a d tap connector?
The title is pretty much self explanatory. I have an IDX X3 lite light that uses a d tap connector. Is there any way I can use an adapter to use it on a newer camcorder?
A d-tap connector, like in the image shown above, is a special type of power cable used to connect devices to large V-mount or Gold mount batteries. The image shown by Comic_Sans_MS shows the end of the d-tap cable that connects to the batteries. The other end of the cable can be whatever shape/size of connection port the device uses, though it usually looks like the power connector for a laptop.
So for your IDX lights, as long as you find a compatible power source that will provide the right amount of electrical power you should be able to use it. It doesn't have to be a d-tap source, it can be an AC adapter, a USB power station, etc. with a suitable connection and right amount of "juice".
Here's an image of a V-mount battery with a d-tap port. The d-tap port are the two copper connection points on the lower side of the battery.
