Noctua and be quiet! are solid if you want to shift a lot of air quietly. Not cheap though.
Other systems I've built:
https://linustechtips.com/topic/452223-case-fans/#findComment-6063757
Where are you putting the fan?
Where are you shopping/located? Budget?
https://linustechtips.com/topic/452223-case-fans/#findComment-6067324
im putting the fan in the front of my case.
Money isnt an issue
I don't suppose you'd ship an item from the other side of the world--it would help to mention where you're shopping/located.
https://linustechtips.com/topic/452223-case-fans/#findComment-6071368
https://linustechtips.com/topic/452223-case-fans/#findComment-6081050
