Power Brick...Does It Matter?
Solved by MblaZe7run,
Just ended up ordering a Sager (forgot the model...), but I got mine with RAID 0 M.2 850 EVO SSDs, 1TB mass storage, 4790K, and 970m, and the 230W was cutting it close as it is, assuming processor and GPU were running at 100% power draw, that alone was 169W. Leaving only about 61W for the rest of the system. Figuring I'll have a mouse, among the other peripherals and parts, 230W was not enough under max load. I ended up getting the 330W because I HAD to. I would do the same in your case, despite not knowing what specs your laptop is..
