As you can see from the title, this is going to be my first PC that I've ever built! I have taken apart my neighbor's old computer, but that's about where my experience ends. So here we go.
I have a budget of around $600-$650 and I want to be able to game with medium-high settings at 1080p. If it matters, I live in USA FL 34601.
Case​​- Corsair 200R $69.99
CPU-​ AMD FX-6300 6 Core 3.5 GHz $96.46
CPU Cooler-​​ Cooler Master Vortex Plus​​​​ $25.99
Motherboard- BIOSTAR ​​TA970 $59.99
Memory- G.SKILL Ares Series 8gb (4x2) $49.99​
Graphics Card- EVGA GeForce GTX 960 4gb $239.99
SSD(I already have a 1tb hard drive that I bought ahead of time for some reason)- Kingston Digital 120GB SSD $50.44 ​
Power Supply- Corsair CX750M 750W $79.99
Case Fans- BitFenix Spectre​ $11.99
​*To clarify, I want all things above to be around $600-$650 and everything below to be around $200 or so.
Mouse- Gamdias Hades $29.99​
Keyboard- Gamdias Ares $34.99​
​Wifi Adapter (I can only have wifi with my living situation)- Rosewill Wireless N150 $11.99 ​
Monitor-SCEPTRE E225W 1920x1080 $​119.99
***All of your support and ideas help, however there are some things that I don't want to have. I don't want to use Intel mostly because of the price, I can't flex on that budget, I'm going to be building it in about a month, I know that prices are subject to change, and I'm going for black with an orange accent on the whole machine. Thanks to all.***
https://linustechtips.com/topic/451732-building-my-first-gaming-based-pc/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($183.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.99 @ NCIX US)
Motherboard: MSI B85M-E45 Micro ATX LGA1150 Motherboard  ($62.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($37.99 @ Amazon)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.73 @ B&H)
Video Card: MSI Radeon R9 380 2GB Video Card  ($199.98 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($52.99 @ SuperBiiz)
Total: $654.65
Generated by PCPartPicker 2015-09-17 18:15 EDT-0400
BigDay
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($175.88 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($198.98 @ Newegg)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($45.99 @ Directron)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ NCIX US)
Total: $656.34
Generated by PCPartPicker 2015-09-17 18:30 EDT-0400
The site has changed....
Get a G3258 now, and pick up an i5 or i7 later.  I have the i3-4160 and it handles everything I throw at it gaming wise at about 50-70% load, and the i3 is basically a hyperthreaded pentium.
Since you have a 1TB HDD, I'd also hold off on the SSD and get a better motherboard.  Especially if you will be overclocking.
I really went for your black theme here.  No need for aftermarket cooling, G3258s are capable of really good overclocks on stock coolers.
Motherboard: MSI Z97A GAMING 6 ATX LGA1150 Motherboard  ($142.98 @ Newegg)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory  ($39.99 @ Newegg)
Video Card: PowerColor Radeon R9 290 4GB TurboDuo Video Card  ($262.98 @ Newegg)
Case: NZXT Source 210 Window ATX Mid Tower Case  ($52.98 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($57.02 @ Mac Mall)
Total: $620.83
Generated by PCPartPicker 2015-09-18 14:58 EDT-0400
To show you just how behind AMD's processors are, here is 2 performancetest benchmarks which is a data pool of user submitted benchmarks.  Even the lowly G3258 keeps up with the FX-6300.  And absolutely shreds it in single core performance, which is very important for older titles.
AMD processors look like the better value on paper, but intel is the way to go man.
post-251563-0-59866400-1442603219_thumb.
@JAS0N83R1337 I like either of the i5 systems above, but I'd use the stock CPU coolers and move that money to buying a larger SSD.  120GBs (111GiB) is not much even for the OS, miscellaneous programs and utilities, pagefile, etc.   You don't want to completely fill it up either. 10-20GB of free space is usually what is recommended.
