There was no sub-forum for help with PC Building so I assumed that this belonged in just the general help section (since this is my first time using these forums).
I'm in the process of looking buy / build myself a new PC this coming Monday, with a budget of £1,000. Unfortunately I have somewhat limited knowledge when it comes to building computers/good computer components. My new PC needs to be able to run intensive computer games smoothly while streaming, other than that I will frequently be editing videos/images and coding.
A somewhat educated (and extremely helpful) friend of mine has been helping me out and this is what he suggested, minus the keyboard and monitor:
https://gyazo.com/2ea61907c5168e2db139597f407d6d35
I do need at least 1 more monitor, and a new keyboard with the £1,000 budget, and help is appreciated - thanks!
https://linustechtips.com/topic/451718-pc-build-help/
yes thier is http://linustechtips.com/main/forum/18-new-builds-and-planning/ and you should use PcPartPicker.com so we can edit the parts and you can see how to get them for the cheapest/if thier compatable. ill look at it and tell you what i think
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056262
it looks good but i wouldn't get a WD Green id get at least a blue or a black the WD green is pretty bad
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056296
Okie, so would something this be okay? https://www.overclockers.co.uk/showproduct.php?prodid=HD-411-WD
What is the difference by the way colour-wise?
Thanks for the help and sorry for posting in the wrong section.
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056353
the main difference is the speed and life of them the Green has been knows for crapping out faster than the blue or black so from lowest to highest quality is Green, Blue, Red, Black or
Greens are for eco-oriented folks who want less power consumption
Blues are your standard vanilla drives
Reds are performance oriented drives that spin at variable rates
Blacks are for enthusiasts willing to shell out a premium
and yes the one you picked will be good
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056381
and make sure you follow all your posts by clicking the  follow this topic button on the ride side above the post so you can see all replies on your post even ones people dont quote you with
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056395
his current build approximately
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  (£169.96 @ More Computers)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard  (£68.36 @ Scan.co.uk)
Video Card: Asus GeForce GTX 970 4GB Video Card  (£251.99 @ Aria PC)
Case: Corsair 300R ATX Mid Tower Case  (£62.34 @ Aria PC)
Power Supply: Corsair Builder 750W 80+ Bronze Certified ATX Power Supply  (£64.99 @ Amazon UK)
Monitor: BenQ GL2023A 60Hz 19.5" Monitor  (£71.71 @ Amazon UK)
Total: £860.59
Generated by PCPartPicker 2015-09-17 22:54 BST+0100
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056412
Thank you, so aside from that I can just order the parts and the build everything using that? :o
you can but you might want to wait for more people to chime in im not from europe so im not familiar with websites that have good deals or anything or the pricing so id just wait until a person who does comes along and can maybe save you money or get you better parts for the money. but its a good build.
but yes that's all the parts you need to make a fulling operating PC
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056425
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (£196.12 @ More Computers)
Motherboard: ASRock Fatal1ty H97 Performance ATX LGA1150 Motherboard  (£79.99 @ Amazon UK)
Storage: Crucial MX200 250GB 2.5" Solid State Drive  (£69.90 @ Scan.co.uk)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  (£249.98 @ CCL Computers)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  (£48.98 @ Novatech)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  (£57.94 @ CCL Computers)
Monitor: Asus VE248H 24.0" Monitor  (£122.99 @ Scan.co.uk)
Total: £1014.67
Generated by PCPartPicker 2015-09-17 23:06 BST+0100
 much better
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056485
Total: £1014.67
 much better
this makes me wish this was in USD id love to have that
https://linustechtips.com/topic/451718-pc-build-help/#findComment-6056504
