I have a simple idea, that i would know how to do, i just don't know of a wireless component to use.  I know that there are shields that I could use to get two arduino to communicate, but i want one arduino, to communicate with some receiver about 10 feet away, that opens and closes a simple LED circuit.
What should i use for the wireless communication between my arduino and a breadboard.
Thanks
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/451553-wireless-led-control-arduino/
Julian has some great arduino tutorials, and specifically some on cheap wireless communication: https://www.youtube.com/user/julius256
Thanks
One option would be to look for a off the shelf add on board.
But if you already have a SD-card slot and you are intereded in a DIY solution you can use a WF111 modu, evalboard aviable on digikey (~150$):
http://www.digikey.com/product-search/en/rf-if-and-rfid/rf-evaluation-and-development-kits-boards/3539644?k=wf111
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
