My system Specs:
CPU: Intel i5 2300
Motherboard: GA-H61M-DS2
Ram: 4GB Kingston
No Graphics card so i was hoping to buy a graphics card under $300 so which could be the best for this outdated CPU because i was not planning to upgrade the CPU anytime soon so which will be the best for Me..
also please do suggest the cooling fans as well.
https://linustechtips.com/topic/451348-need-help/
Anything you could get for $300 would work fine with that cpu.
Steve Wozniak - "Never trust a computer you can't throw out a window."        Carl Sagan - "If you want to make an apple pie from scratch, you must first create the universe."
CPU: Core i5 6600K Cooling: NH-D14 Motherboard: GA-Z170XP-SLI RAM: 8GB Patriot Graphics: Sapphire Nitro R9 380 4G Case: Phanteks Enthoo Pro HDD: 2TB Seagate Barracuda PSU: Threamaltake Smart 750W
My computer runs on MSX, Its very hard to catch.
https://linustechtips.com/topic/451348-need-help/#findComment-6051631
R9 380 4GB and use the spare money to throw 4 more GBs of ram in there
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/451348-need-help/#findComment-6051659
My system Specs:
CPU: Intel i5 2300
Ram: 4GB Kingston
Are you from India? because i am from India too.
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
https://linustechtips.com/topic/451348-need-help/#findComment-6051744
gtx 950's are quite cheap at the moment, if you want an alternative to amd (WAIT!!! i don't want to start WW3, i am NOT critiscizing amd cards...) you can get the ftw edition for 180 $ i think.
R5 3600x | RTX 3070 | 16Gb 3200mhz | Gigabyte B550 gaming x | 500gb 660p SSD + 1tb wd blue HDD |
https://linustechtips.com/topic/451348-need-help/#findComment-6051747
Any GPU Thats Under 300 Dollars Will Work Great With This GPU, And I Recommend The EVGA Geforce GTX 960 4GB FTW ACX 2.0 Model Which You Can Buy Here...   http://www.evga.com/Products/Product.aspx?pn=04G-P4-3968-KR   Right Now It Costs 259 Dollars And You Should Spend The Spare Money Also To Get 8 Gigs Of Ramattachicon.gifCapture.PNG
This 290 costs less, and is a fucking boss ass bitch when compared to a 960.
https://pcpartpicker.com/part/powercolor-video-card-axr92904gbd5tdheoc
And really we all know 4gb is useless on a 960.
https://linustechtips.com/topic/451348-need-help/#findComment-6051779
I was also hoping to change my psu to corsair cx500.. Also want to know is it ok to go with msi GeForce gtx 960 4gb and I also kinda like the idea to upgrade ram by 4gb so will this be great idea??
CX PSU is garbage.
4gb on a 960 is useless.
Also the budget is 300$ but what currency us or nz?
https://linustechtips.com/topic/451348-need-help/#findComment-6052199
CX PSU is garbage.
That's what everybody suggested me so i also decided to upgrade my ram by 4 gb i.e. total of 8 GB .. so with 8GB  960 is fair enough to keep up .. the only thing that is left with is PSU so if there anything better than CX suggest please .. and for the budget i would say it will be NZ currency but i can get bit over than 300 may 50 or 100 i guess ..
https://linustechtips.com/topic/451348-need-help/#findComment-6052397
Everything is so expensive in NZ.. what's your budget for a PSU is that part of the 300-400 budget. And what merchants do you guys use?
https://linustechtips.com/topic/451348-need-help/#findComment-6054262
no i'm raising fund for PSU so it will be 100 or 150 at the time when i buy all the stuff.. and yes i do know here eveything is damn expensive .. well i'm trying my best so please do suggest the PSU as well and if possible better graphics card with same price bracket .. and Thanks for helping me out to all :)
https://linustechtips.com/topic/451348-need-help/#findComment-6057282
