Python Help! Basic Loops Not Working
Go to solution Solved by Nineshadow,
@xGear
This should fix it :
Num1To10Guess = int(input ("What number do you guess?"))
Yup, it works, tested it myself.
Hi, I am trying to create a number guessing game, but it won't work. There is an error somewhere in the loop, its seriously doing my head in and any help would be appreciated. It won't register when the right number is entered and doesn't accept or find the number. If you paste the code from below into python shell 3.4 you will see:
import random
from time import sleep
print ("This game is a simple guessing game") ; sleep(2)
print ("A random number will be generated") ; sleep(2)
print ("And your aim is to guess the number correctly") ; sleep(2)
print ("The game will start in:") ; sleep(2)
print ("3") ; sleep(1)
print ("2") ; sleep(1)
print ("1") ; sleep(1)
print ("**Game Started**")
Num1To10 = random.randint(1, 10)
Lives = 12
print ("Round 1:")
print ("A number between 1 and 10 has been generated, can you guess it? You have 3 chances to guess correctly") ; sleep(1)
while Lives > 0:
    Num1To10Guess = input ("What number do you guess?")
    if Num1To10Guess == Num1To10:
        print ("You guessed correctly, moving onto next round")
        break
    if Num1To10Guess != Num1To10:
        Lives = Lives - 1
        print ("Incorrect! Try again!")
    else:
        print ("You failed round 1 and ran out of lives")
        print ("**Game Over**")
        break
As you can see it is very basic but isn't working properly. I hope someone can fix it or help me, thank you very much, Ben.
https://linustechtips.com/topic/451048-python-help-basic-loops-not-working/
@xGear
@xGear
You Sir! Are a legend! Thank you so much :)
Also, do you have any suggestions on getting the game over bit to work? Thanks again :)
@xGear
Ahh I figured it out, just shift the game over into another while loop which checks if the lives equal 0 and that works fine.
Thanks again for your help, you saved me! Awesome!!!! :)
