I'm building a gaming pc and it going to be in my bedroom (2nd story). my home pc is on the first floor with the router. I can't run a cord down my step so I have to use either wireless or Powerline. Which one is the better option in terms of my budget and performance? I don't want to spend to much more that 50$. What are some trustworthy/good models?
https://linustechtips.com/topic/450608-wireless-or-powerline/
Powerline
https://linustechtips.com/topic/450608-wireless-or-powerline/#findComment-6041667
depends, on two factors you cant test:
1: how well a powerline will work in your house.
2: how well wifi will work in your house.
EDIT: should clarify:
1: depends on the wiring and how noisy the power is.
2: depends on the amount of interference on 2.4GHz and 5GHz, on how thick your walls are, and how well you can point your antennas.
https://linustechtips.com/topic/450608-wireless-or-powerline/#findComment-6041748
