CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($132.98 @ Newegg)
Storage: Samsung 850 Pro Series 128GB 2.5" Solid State Drive  ($84.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($334.98 @ Newegg)
Case: NZXT H440 Designed by Razer™ ATX Mid Tower Case  ($128.99 @ SuperBiiz)
Total: $1151.69
Generated by PCPartPicker 2015-09-14 23:43 EDT-0400
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/450230-pc-build-with-h440/#findComment-6036121
Hey I wanna build a pc with the h440 razer case the budget it around 800-1200s its gonna be used to play some but not all steam games league of legends and world of Warcraft. also watching/streaming on twitch and watching 1080 movies with torrents
What @Amazingasian put together is pretty decent, however it does have some flaws like using the 850 Pro SSD instead of the Evo one.
Here's an improved version of the build for less. Twice as much RAM, twice as big SSD, twice as big, better quality HDD and a more powerful CPU especially in multithreading since it features 8 threads, much better for streaming on Twitch as you'll be doing. It's basically the best build in terms of performance per dollar you can possibly get (not counting the case, you just wanted this particular one).
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: Asus Z87-A (NFC Express Edition) ATX LGA1150 Motherboard  ($59.00 @ Newegg)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1600 Memory  ($76.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.89 @ OutletPC)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($117.11 @ Amazon)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ NCIX US)
Total: $1114.83
Generated by PCPartPicker 2015-09-14 23:53 EDT-0400
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/450230-pc-build-with-h440/#findComment-6036179
Do you need a monitor with it as well?
Otherwise, you could just slap a razer logo on a less expensive case so it doesn't cut into your budget, but I don't personally really care about aesthetics so...
There ya go, Xeon 1231v3 + 390, bit of room for an SSD and the like, but with a silencio case.
http://pcpartpicker.com/p/KQp8t6
https://linustechtips.com/topic/450230-pc-build-with-h440/#findComment-6037046
