It would help to mention where you're shopping/located, budget, and where the fans are being used.
https://linustechtips.com/topic/449405-fans/#findComment-6025331
location, NJ, USA and i need some af and ps
Where are the fans being used?
Sp
There's an option to edit your posts.
https://linustechtips.com/topic/449405-fans/#findComment-6031673
im going to put two fans on the front(af) 4 on a top radiator (sp) three on the radiator at the bottom of the case(sp) and one on the back (af) for cool air to come in.
What fan size and in what case?
https://linustechtips.com/topic/449405-fans/#findComment-6039177
phanteks enthoo primo and 140 mm
If you can afford it, all NF-A14's would be great. http://pcpartpicker.com/part/noctua-case-fan-nfa14pwm
https://linustechtips.com/topic/449405-fans/#findComment-6043524
thats static pressure but what about air flow?
NF-A14's have good airflow along with static pressure.
https://linustechtips.com/topic/449405-fans/#findComment-6050811
o dont know if i should use the same fan to do everything
They'll be fine for that.
https://linustechtips.com/topic/449405-fans/#findComment-6054462
i mean specifically for air flow and another specifically for static pressure
"NF-A14's have good airflow along with static pressure."
Silent Wings 2's have a bit better airflow/noise but the Enthoo Primo has a bit of restriction to their panels and NF-A14's/SW2's don't exactly match well.
https://linustechtips.com/topic/449405-fans/#findComment-6065190
