Do i need a CPU upgrade?
Go to solution Solved by OAcesync,
well mainly League and H1Z1, i also play gta v
Yep CPU upgrade is a defo but what GPU is it
Allright so i want to get a I5 4690k but my friends are saying i just need to get a better gpu and not waste money on my cpu. I have an amd fx 4130 btw. please tell me im right and i need a beter cpu.
CPU Ryzen 5 3600 | Motherboard MSI B550 | RAM 32 GB Corsair Vengance Pro | GPU EVGA GTX 980ti | Case Corsair 4000X | Storage Seagate Barracuda 2TB HDD,  Team GX2 1TB SSD | PSU Sentey 850w 80+ Bronze | Cooling AMD Wraith RGB | PCPartPicker URL https://pcpartpicker.com/list/RN7kGc |
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/
Depends, what games @lilwic?
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024109
well a bulldozer chip wouldn't hurt to be upgraded. But your video card is more important.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024110
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024117
Question what GPU do you have? Its not a bad idea to upgrade yet I think the GPU depending on what you are running matters at this point.
Regards Elias N Martinez. | Graphic and motion design are my jobs. 3D modeling is my hobby. I do what I enjoy.  Skype: eliasnmartinez1 (please state that you are coming from LTT)
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024124
what is your build?
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024127
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024131
if you still have the gtx 560 upgrade the video card first.
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024140
What gpu do you have?
What do you want to do, gaming? What games, res and settings?
what is your build?
i have an amd fx 4130 like i said and a GTX 560 SC
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024144
ok
https://linustechtips.com/topic/449299-do-i-need-a-cpu-upgrade/#findComment-6024153
