So my friend was playing league of legeneds and Minecraft fine with fps that we was okay with
when he restarted his computer that night he got bluscreen and got stuck in a loop
he then reinstalled windows
installed all the drivers
but now minecraft wouldnt work
was getting "Bad video card driver"
but he used geforce experience to update so i know it wasnt that
then i thought it was a laptop so it might have the silly 2 video cards thing in it
so i got him to install the intel driver to
then minecraft worked
but......
then he was only getting about 3-10fps
we have tried intalling new Java
deleting the .minecraft folder
but still having the same problem
un-installing and reinstalling drivers for both cards but
still cant figure it out
ive never seen this problem before
plus have looked on the internet for solutions but cant find any that work
Any ideas very much welcome :D
Thanks
https://linustechtips.com/topic/44917-help-s/
Can you upload the dump files for the BSOD as explained in this thread, and you will also get more people to help you if you change the thread title to something like "BSOD with video driver issue intel HD4000+<whatever GPU>" (To change the title, edit your original post and click on "Full editor", then there's a field to change the title.
Upload the dump files from C:\Windows\Minidump in a compressed archive (.zip etc) to the forum using the "Attach Files" button under the editor. This allows us to read the error messages and diagnose the problem effectively and quickly.
HTTP/2 203
https://linustechtips.com/topic/44917-help-s/#findComment-590878
