Please suggest INTEL/NVIDIA Build.
Cheapest possible,that can afford play witcher 3 1080p with decent fps like 40-60 on medium/low graphic,Fallout 4 60fps+ also high/medium graphic,Skyrim on High graphic 60 fps+.
And other games I play:
CS:GO,LoL,Diablo3,Starcaft2,Black Desert(one of main ames I want to play  with Fallout 4).
https://linustechtips.com/topic/447377-suggest-a-build/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.88 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Video Card: Sapphire Radeon R9 380 2GB Dual-X Video Card  ($198.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ NCIX US)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Newegg)
Total: $644.51
Generated by PCPartPicker 2015-09-10 07:25 EDT-0400
Im sorry but the 380 destroys the 960 at this price range and its better for the money
the 4 GB 380 if you want even more performance and can afford it
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5997653
Total: $644.51
those prices are insane r9 380 is like 240 eurs here  , but still 644 is more than I can afford
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5997666
then whats your budget?
Rigs I've Built
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5997673
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor (€80.05 @ Mindfactory)
Motherboard: ASRock FM2A68M-DG3+ Micro ATX FM2+ Motherboard (€48.89 @ Amazon Deutschland)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory (€51.41 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€55.93 @ Mindfactory)
Video Card: PowerColor Radeon R9 280X 3GB TurboDuo Video Card (€187.89 @ Mindfactory)
Case: Cooler Master N200 MicroATX Mid Tower Case (€45.14 @ Amazon Deutschland)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (€66.42 @ Amazon Deutschland)
Total: €535.73
Generated by PCPartPicker 2015-09-10 13:37 CEST+0200
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5997703
Says must be cheap.
Says must be Nvidia based.
These things do not work together.
you saying amd never sold overpriced things? seems like it, don't jump on the fanboy bandwagon mate, its not a good luck.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5997737
Hunlight,
Here's my recommended computer build.
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($84.99 @ Amazon)
Memory: Team Vulcan 16GB (2 x 8GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Video Card: EVGA GeForce GTX 960 4GB Superclocked Video Card  ($213.98 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($35.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($57.99 @ SuperBiiz)
Total: $690.71
Generated by PCPartPicker 2015-09-10 08:35 EDT-0400
Buzzsaw - I'm Buzzsaw and you're not.
CPU -- Intel Core i7 7740X @ 4.30GHz Kaby Lake 14nm Technology * RAM -- 16.0 GB Dual-Channel Unknown @ 1466MHz (15-16-16-35)
Motherboard -- ASUSTeK COMPUTER INC. TUF X299 MARK 2 (LGA 2066 R4) *
Graphics -- SAMSUNG (1920x1080@59Hz) -- 4096 MB ATI Radeon RX 560 Series
Storage -- 223 GB SanDisk Ultra II 240GB (SSD) -- 256 GB Crucial_CT275MX300SSD1 (SSD) -- 931 GB Western Digital WDC WD10EZEX-00BN5A0 (SATA) -- 2794 GB BUFFALO External HDD USB Device
Optical Drives -- ASUS DRW-24B1ST * Audio -- Realtek High Definition Audio
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5997986
Hunlight,
Total: $690.71
thanks for that price I could just build it my self I need cheaper something near 500$
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5998630
Good luck finding a solid computer build that can play those games at that price point.
I'd recommend that you save up another $200, then you can get those components that I suggested and build it yourself.
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5999075
I cant save im after surgery at home and willbe like this another half of the year so parents gifted me some cashto upgrade my pc and have some "smiley" thats why I can afford only about 500 mby little more.
And I understand that I can get pc on amd much cheaper and play witcher 3 on low/medium then but then I could upgrade it to like i5 or i7 next year (I mean 2017)
https://linustechtips.com/topic/447377-suggest-a-build/#findComment-5999872
