would this fix problem
My sub isn't being used in music due to multi channel outputs not being processed.
If from the front I go-
Front-sub in-sub out-receiver
Then would my sub be used?
https://linustechtips.com/topic/447376-would-this-fix-problem/
You mean using the high level inputs on the subwoofer?
Not clear on the whole line level/high level/speaker level stuff.
I mean using the rca connectors
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-5998352
the cables should be color coded
just plug them into the right color
and play some 5.1 audio
and it should work fine
if you have the right drivers installed
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-5998368
Yeah I know how to plug in cables...
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-5998375
How are you connecting the sub to your receiver right now?
Via the sub out.
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-5998998
So a single RCA cable connecting your sub pre-out to the L or R channel into your subwoofer?
Yeah.
But since there is no proccesing for multi chanel, i get no sub in music.
But, i was thinking, if i go from front speaker out on pc, to rca sub in, then from the rca out on the sub, and then from that to the receivers front chanel, then the sub should proces the signal, and i should be able to controll it using the low pass filter, correct?
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-5999314
Yeah.
You have the PSW10, right? I don't see an RCA out. Typically subs don't have an RCA out. You usually need to use the inputs and outputs with spring connectors to pass through your audio.
You should have enough left over speaker cable to accomplish this. First you need to connect the left and right front channels from your receiver's speaker outputs to your subwoofer's "Speaker Level Input." Then you connect the subwoofer's "Speaker Level Output" to your front speakers. Your subwoofer will be inline with your fronts and process the bass on its own using the built in low pass filter.
However, I would also connect the subwoofer pre-out to your subwoofer using an RCA so your receiver can send any LFE signals that it processes.
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-5999940
Oh I forgot, I'm at school ATM.
OK I don't think I'll bother with that now, as my sub does not positively effect music.
I'll do that if I get a better sub
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000156
It's not really that big of a deal. It's just a few more cables. You probably have some left over from that giant roll you purchased.
Your choice though. Focus!
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000238
Yeah, I can also just press a button to change my receiver to stereo input then I get the sub. I kinda forgot about that.
I do have a lot of the roll left over, but I want to save it.
Idk why...
I also made some molex to fan adapters with it.
Also, I was in passing time.
That's why I replied every 40 minuets
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000428
Idk why...
Don't stress too much about trying to save it. You can always get more later.
Using stereo mode might be the fastest/cleanest alternative. Unfortunately, receivers have a tendency to complicate life a bit.
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000558
Yeah.
Problems with every connection for PC.
Optical-
Game support
Hdmi-
Multi monitor problems
Multi channel-
No processing.
The main problem probably is that receivers are not made for PC's.
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000584
Yeah.
Optical-
Game support
Hdmi-
Multi channel-
No processing.
That is the unfortunate truth. They are made for home theater surround sound.
Multi channel might be worth investigating. There might be software/drivers that does the processing at your PC before transmitting the separate channels.
But yeah it's a pain compared to a boxed speaker set.
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000862
Yeah I can probably find some sort of software.
But so far multi channel works pretty well
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000900
I switched back to 2 speakers with a sub, and an optical connection has been working well for me. I just kind of ran out of room with all the speakers for surround. It's like the most incredible thing I've heard, but it takes up way more space than I'd like.
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6000946
Optical-
Game support
All games with multichannel support should work with Dolby Digital Live (or DTS Connect). You can give that a try, if you can.
I've used both for the longest time before I switched to HDMI.
http://www.dolby.com/us/en/technologies/dolby-digital-live.html
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6001051
My motherboard doesn't have optical out.
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6001088
Oh okay. Not even SPDIF header pins?
I dont beleive so.
its a 50$ AMD motherboard so....
Its really a bad motherboard, no VRM heatsink, cant OC.
Im lucky it has analoge out
https://linustechtips.com/topic/447376-would-this-fix-problem/#findComment-6001176
