work build
Go to solution Solved by Morgan MLGman,
hello i need somebodys help top build a work stachion build for around 650$ with a wireless adapter thanks
I guess this would be good price to performance-wise, however I'm not sure how powerful of a GPU do you need. This one should be pretty powerful for a video editing workstation:
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($139.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($85.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory  ($76.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: PowerColor Radeon R9 285 2GB TurboDuo Video Card  ($158.98 @ Newegg)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case  ($42.99 @ Directron)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($79.99 @ Newegg)
Wireless Network Adapter: TRENDnet TEW-805UB 802.11a/b/g/n/ac USB 3.0 Wi-Fi Adapter  ($23.88 @ Amazon)
Total: $670.28
Generated by PCPartPicker 2015-09-08 20:45 EDT-0400
What kind of work will you be doing on this PC? Do you need a monitor and peripherials?
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/446617-work-build/#findComment-5986463
this is what i made up
PCPartPicker part list: http://pcpartpicker.com/p/RNyYFT
Price breakdown by merchant: http://pcpartpicker.com/p/RNyYFT/by_merchant/
CPU: AMD FX-6350 3.9GHz 6-Core Processor  ($128.98 @ Newegg)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard  ($102.98 @ Newegg)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($96.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($52.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($74.99 @ Newegg)
Video Card: EVGA GeForce GT 740 1GB FTW Video Card  ($76.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($88.98 @ Newegg)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($39.99 @ Newegg)
Wireless Network Adapter: TRENDnet TEW-805UB 802.11a/b/g/n/ac USB 3.0 Wi-Fi Adapter  ($27.99 @ Newegg)
Total: $680.87
Generated by PCPartPicker 2015-09-08 20:42 EDT-0400
https://linustechtips.com/topic/446617-work-build/#findComment-5986613
Total: $680.87
This wont work well, at all.
https://linustechtips.com/topic/446617-work-build/#findComment-5986616
Total: $670.28
https://linustechtips.com/topic/446617-work-build/#findComment-5986644
I guess this would be good:
Total: $670.28
thats a good system thanks
https://linustechtips.com/topic/446617-work-build/#findComment-5986649
You're welcome, I included a better than stock CPU cooler and a motherboard with good VRM so you can overclock the CPU =)
https://linustechtips.com/topic/446617-work-build/#findComment-5986664
yea im probly going to buy the parts tommorow
Sure, don't forget to provide some pictures of the build after you completed assembling it, would be nice to check out how it all looks =)
Throw in a Samsung 850EVO 120GB SSD after you grab some spare money later on so the PC usage experience would be better
https://linustechtips.com/topic/446617-work-build/#findComment-5986693
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($193.99 @ SuperBiiz)
Motherboard: ASRock Z97M-ITX/AC Mini ITX LGA1150 Motherboard  ($105.99 @ SuperBiiz)
Memory: Patriot Viper 3 16GB (2 x 8GB) DDR3-1600 Memory  ($84.99 @ Amazon)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($79.00 @ B&H)
Video Card: Gigabyte GeForce GTX 750 Ti 4GB Video Card  ($149.99 @ Amazon)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($21.99 @ Micro Center)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Total: $680.94
Generated by PCPartPicker 2015-09-08 20:55 EDT-0400
corsair 600t, msi z87-g45, intel 4770k, 16g patriot viper low-pro ram, asus direct cu2 780, crucial 256gig ssd, seagate baracuda 1tb,
https://linustechtips.com/topic/446617-work-build/#findComment-5986730
Total: $680.94
thanks but mlgman got me a good build
https://linustechtips.com/topic/446617-work-build/#findComment-5986764
