I bought this PSU for my new PC and after one day of usage I realize that a weird sound was coming inside of it. It's like the fan is hitting something while spinning. I took a video so you can hear it and tell me what I have to do, to contact corsair, or test something.
https://www.youtube.com/watch?v=QWn7upejrY4
https://linustechtips.com/topic/446504-cs550m-weird-sound/
RMA?
Other systems I've built:
https://linustechtips.com/topic/446504-cs550m-weird-sound/#findComment-5984896
Just RMA it
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/446504-cs550m-weird-sound/#findComment-5984933
Sounds like the fan is hitting something. Or it could be an issue with the fan bearing. Flip the PSU upside down and see if there is something obstructing the fan blade area, like a wire.
If that noise is not produced by any obvious physical means, then I'd recommend that you have it replaced. It's a brand new PSU, I am sure the store where you bought will have no problem swapping it for a new unit.
https://linustechtips.com/topic/446504-cs550m-weird-sound/#findComment-5985696
RMA before it goes nuclear ^_^
https://linustechtips.com/topic/446504-cs550m-weird-sound/#findComment-5990314
Hahah thank you for your answers! I already contact the store and they told me to complete a form and send it back, but they also said that it's nothing to worry about. Well after all I read I think I'll pick another one. Any suggestions? I like it to be modular or semi-modular and really quiet!
https://linustechtips.com/topic/446504-cs550m-weird-sound/#findComment-5991525
EVGA G2 or GS series, XFX XTR series, pretty much anything from Seasonic, etc. Consult this list to check PSU quality, tiers one and two are really what you should be aiming for: http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
https://linustechtips.com/topic/446504-cs550m-weird-sound/#findComment-5991590
Thank you for your help. I think I'll go with the XFX XTR 550. :)
Will it be possible with the RMA to change my PSU with this one and pay the extra cost?
https://linustechtips.com/topic/446504-cs550m-weird-sound/#findComment-5991819
