Hi guys
So I plan to buy the ASUS B85M-G because of the great price, the quality asus provides, and the fact that it received a bios update from ASUS which allows for overclocking. And I have seen people push the 4670k to 4ghz easily on this board.
Now i see this message:  http://www.bit-tech.net/news/hardware/2013/07/25/intel-overclocking-block/1
it states intel will be doing a microcode update to prevent overclocking on non Z platforms.
I am wondering what this means, does it mean if I just dont update my drivers I will be able to overclock forever?
And if I do happen to buy a motherboard with the microcode update, can I downgrade from it?
https://linustechtips.com/topic/44583-b85-overclocking-soon-not-possible/
dont update your bios and you will still able to overclock it
Its a decent board, however there isnt really space for something like a sound card unless you dont put a graphics card in.
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
How is that an answer to my question??
Sorry, just thought i would tell you what i think of it since i have it, look at the guy above me.
i heard rhat it will be something in windows itself instead of the bios that prevent from overclocking on non z87 platforms, i could be wrong dough
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
if so just disable anything but C1E and C3-C6 states in bios so that intel's management software wont able to slow the cpu down
