Budget? I can recommend the Asus PCE-AC56
Hello,
I need a PCI express adapter for my main PC, preferred it to be AC because my AP support it.
¿Which one will you recommend?
Thanks.
Asus PCE-AC68 if you're after the best wireless speed below $100. It's unlikely to bottleneck a connection (that normally happens on the router end with these high grade adapters).
Thx for your replies.
My Router/AP is the Asus RT-AC66U, i don´t there will be bottleneck on the connection of 300 Mbps Up and 30 Mbps Down.
The budget will be anything under 100€.
i am interested in the Asus PCE-AC68 found it for 62€
