I am hoping to purchase a new graphics card soon but not sure which one. My current is a geforce gtx 760. my pc specs are intel core i5-4570  8 gb of ram
 thank you very much Rowan
Budget? Currency? Location? What case do you have? What power supply? Motherboard? Cooler?
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/445285-please-help-me/#findComment-5967012
what do you want to spend? for what purpose are u using it? resolution?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/445285-please-help-me/#findComment-5967014
GTX 960
Going from a 760? did you even read the post? That would be pretty pointless.
https://linustechtips.com/topic/445285-please-help-me/#findComment-5967101
what then ? 970 ?
We need more information before we can make a suggestion. But yeah a 970 or a 390 would be the better option if its within budget and will work with his PSU etc
https://linustechtips.com/topic/445285-please-help-me/#findComment-5967142
One of these:
gtx 970, 980, 980ti
R9 390, 390x, Fury
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/445285-please-help-me/#findComment-5967255
With your current budget and components I would personally recommend you get a different cpu cooler such as this;
http://eu.coolermaster.com/it/cooling/hyper-series/hyper-212-evo/
Then I'd look at either picking up a 390 or 970. Out of my personal choice of the two I'd recommend going for the 390 and if you want to spend more then look at getting a 980 instead.
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
https://linustechtips.com/topic/445285-please-help-me/#findComment-5982461
