Half display flicker?
Solved by W-L,
If i set up an eyefinity group wont that mean it will use both monitors for games and stretch the picture between the two?
Yes that would stretch it over the two screens, if you wanted to game on single screen only way would be to disable a display to get rid of that flicker, it's a bit strange that putting the GPU on stock speeds would still cause it to flicker however that's the first time I've seen that happen.
