Audio crackling
Go to solution Solved by red_jelly,
I fixed the problem for somereason it was using my soundcard as a pass-through and it wasn't emitting sound from it. So i changed that and all my problems are solved :D Thank you guys
Hey guys so i have a problem. When ever i open a window up i get a crackling noise from my headset. I'm using the Astro A40's wireless mixamp, it's plugged in with optical in a Asus Xonar Dx sound card. Help please. :)
Cpu: 5820K @4.0GHz   Motherboard: Gigabyte X99-SLI    Ram: Patriot Signature 16GB @ 2133   GPU: Gigabyte G1 980  Soundcard: ASUS DX
 Speakers: Logitech Z906 and Astro A40's   Keyboard: Logitech G510
https://linustechtips.com/topic/44476-audio-crackling/
I've seen someone with that same problem but it only crackled when he touched the volume controls on the headset cord. That was with the 2013 edition. Honestly I don't know what to say other than that except maybe just check that the optical cable is plugged in firmly.
https://linustechtips.com/topic/44476-audio-crackling/#findComment-583274
It is plugged in properly. is there anyother reason why it would do this?
https://linustechtips.com/topic/44476-audio-crackling/#findComment-583307
This just sounds like a bad pot to me, however OP's problem seems different. The fact that it only happens when you open a new window means it's definitely a software problem. Do you have the latest drivers?
https://linustechtips.com/topic/44476-audio-crackling/#findComment-583338
I had the same problem for a while, I think I solved it under linux with a low latency kernel and on windows by using asio4all.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/44476-audio-crackling/#findComment-583347
Found the problem.
Enjoy those tacos now, for in 1000 years they will be illegal... eh Ha Ha Ha! I think we all know why.
༼ つ ◕_◕ ༽つ Give tacos ༼ つ ◕_◕ ༽つ Poker 2 KB Review
https://linustechtips.com/topic/44476-audio-crackling/#findComment-583384
Don't start being that guy.
I'll be whatever guy I want to be, guy.
https://linustechtips.com/topic/44476-audio-crackling/#findComment-585325
https://linustechtips.com/topic/44476-audio-crackling/#findComment-586414
