My 750 ssd is not showing up under "devices/units". . . Need help! Will explain more if you ask.
Why would you not just give us the rundown by default
https://linustechtips.com/topic/444731-help/#findComment-5959967
Well.. i just bought the SSD and plugged it in, when i tried to start the system i forced me to reinstall windows (i have a HDD with windows on it). When the install was done the ssd dident show up. I know its on the right PICe slot and know that the motherboard is compatible (the SSD is deteded on "board exploration"). thats pretty much it
https://linustechtips.com/topic/444731-help/#findComment-5960010
Check to make sure you have the most current BIOS/UEFI revision.
Contact motherborad manufacturer and check compatibility.
Check boot devices in BIOS/UEFI.
Check CSM module to ensure UEFI device drivers are priority and PCIe boot is enabled.
Try booting with no other drives attached.
Try booting the SSD in another computer.
https://linustechtips.com/topic/444731-help/#findComment-5962270
