So ive been kind of scared of posting boring questions like math on this forum although this time its a real emergency, my brain doesnt work, and i have to solve this problem
anyway, can someone please show me how to solve this math problem, and please provide me with as many notes as possible
"factorize the expression"
xy(1+x)-(1+x)
and apparantly according to the book, its supposed to be
(xy-1)(1+x)
What i tried to do:
xy(1+x)-(1+x)
xy = t
t(1+x)-(1+x)
t+x2*y - (1+x)
xy + x2*y - (1+x)
xy + x2*y - (1+x)
x(y + xy) - x(1)+1
y+xy - 1+1
y+xy
But it didnt work
Thanks for helping me
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/444520-simple-math-problem-help/
How did you get xy(1+x)-(1-x) equals xy=t  how did you get a t. You just can't add things to "help".
Firstly you need to remove the parenthesis via multiplying what is outside the parenthesis to what is inside the parenthesis, then do the subtraction.
Your answer could also be (1+x)(xy−1), it is the same as the books answer it just depends on who you cross multiply.
Edited by Leonard
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957326
i didnt add t
t = x*y, it was just to simplify things, you see that i add it back later
t+x2*y - (1+x)
xy + x2*y - (1+x)
also with your second tip, it would look like this
xy(1+x)-(1+x)
xy+x2y-(1+x)
xy+x2y-1-x
And then i cant go any further
edit, although if i factored the answer, it would look like this
x(y+xy-1) - 1
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957367
For simplicity, lets let (1+x) = p. That makes the original expression xyp-p. If we now factorise that to take the ps out, it becomes p(xy-1). If we substitute the (1+x) back into p, we get the expression that you were expecting, (1+x)(xy-1)
Hopefully that makes a bit more sense to you.
HTTP/2 203
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957392
That wolfram answer just expands the brackets, collapses them again, then says "factorise it". Step 3 is identical to step 1.
It proves that the answer is correct, but it's not really helpful for the OP.
HTTP/2 203
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957444
This is what the app "Photomath" says.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957465
xy(1+x)-(1+x)
xy+x2y-(1+x)
What you for got to do is remove the last set of parenthesis using the - sign as well, which would give you xy+x2y-1-x and not xy+x2y-(1+x)
This is a great site for help with math.
Edited by Leonard
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957467
ah, ok never thought about turning (1+x) into "p"
i got it now
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957478
yeah, but still its far from the easiest way to do it
and i would have to factorize it back to get (xy-1)(1+x) after that
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957492
will try this app in the future, although maybe you used the wrong options, since the equation almost got longer than it was in the beginning
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957519
i got it now
You don't need to substitute it for anything else, but if you're struggling to figure out the solution and you know the answer that you're looking for, it's well worth finding things that clearly haven't changed between the question and the answer and replacing them with a single letter to simplify the algebra. The idea is that eventually you get good enough at it that you never need to substitute.
A lot of apps do end up overcomplicating it because they will have set ways to do things, and they probably won't be the most efficient way to do any particular question.
HTTP/2 203
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5957546
Simple? shiit
simple as in not rocket science
although it probably is rocket science if you haven't had the math course that explains it
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5958455
But it's so easy...
xy(1+x)-(1+x) = (1+x)(xy-1)
without any other necessary steps.
Replace 1+x with z if you still don't see it.
xyz - z = z(xy-1)=(1+x)(xy-1)
It's just the simple factoring.
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5958486
But it's so easy...
You know how you cant see the simplest problem untill someone points it out for you, that is what happened to me here, and i knew that it was going to be a really simple answer, so thats why i wrote it in the title
Thanks to all of you who wrote different ways to solve this, i think its really going to help me get through this mess
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5958558
I know that feeling when you miss probably the simplest thing ever, but come on, this is really easy.  I mean, I learned about it in the beginning of the 5th grade.
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5958578
This equation is from a 11th grade book
(aka second year high school - civil engineering)
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5963914
(aka second year high school)
Forgot to mention school is Romania is a lot harder than in most other countries.
These are some problems we had at a test in the beginning of the 9th grade (1st year of high school, ) :
1.Demonstrate that Egs8u6m.pngis divisible by 19 whatever value of n (natural)
2.Demonstrate that  XbWzMZg.png(n natural and bigger or equal to 2)
3. [apgxfqX.png] = ?
where [x] is the smallest integer smaller or equal to x.
5. a + b + c + d = 1
Demonstrate that JBZv3wO.png< 8
8.Demonstrate that p8XJs4d.png>= 3/2  ( Nesbit's inequality)
These are pretty damn easy for me now and we've moved on onto more complicated stuff, so...
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5963929
"a + b + c + d = 1"
What?
it could be anything
0,25+0,25+0,25+0,25
etc
edit: aha i see, there where more to that question
also, atleast in sweden, 9th grade is still in elementary school, and some of these i could actually do in 9th grade, although most of them are extremely overcomplicated
and, would you really need this knowledge in real life even if everyone chose civil engineer, and other math heavy educations (if that is what those are targeted towards) i mean here in sweden we have way easier calculations and even then there is a lot of shit i will never get to use, this looks like an extremely uneffective way to educate kids
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5966886
But it's so easy...
LOL are they all serious, your solution was the fastest and simplest.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/444520-simple-math-problem-help/#findComment-5967671
