Can you use one to cut through 3/4 inch thick plywood?
Or is it not strong enough?
https://linustechtips.com/topic/444027-rotary-saw/
depends on the saw and the blade you have on it. What do you have? (probably yes though, wood is generally easily cuttable)
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951057
definitely strong enough. just make sure to not just jam the blade in to the plywood, but just kinda ease it in there and then gradually cut it to size.
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951061
Uh idk, just found it in my garage.
It says "dremel advantage high speed rotary saw"
And has some random end thing that looks like a dril bit
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951075
It should easily manage to cut through that. Just go slow and steady.
Just go slow and you should be fine.
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951077
If you mean circular saw yea it can easily cut through that no problems.
No, I mean rotary saw
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951083
so its like a small dremel with a circular bit on the end, or like that desk top saw with a 150mm+ blade size? the small one might have a problem, but if its anything remotely large (like 10cm or more) then its easy
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951091
Ok
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951094
Do you have a photo of it ideally a table saw or circular saw will cut through plywood and boards like butter.
If your talking about theses they work very similar to a router but will a milling bit:
http://www.amazon.com/Dremel-Advantage-High-Speed-Rotary/dp/B0009P8E9U
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951101
It's this:
https://www.google.com/search?q=rotary+saw&client=ms-android-sprint-mvno-us&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAmoVChMIx93elJfexwIVDemACh19uQdY&biw=360&bih=511#tbm=isch&q=dremel+advantage+rotary+saw&imgrc=Rlai7O4lRoRNGM%3A
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951105
That's it in the link.
What exactly does a router do?
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951113
Yeah I have a circular saw.
I could use that.
But they are more scary.
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951126
is it a hand held dremmel ?
cus then hell no
if its this : http://images.dremeleurope.com/general/en/ocs/image/ocsjpg--/dremel%C2%AE3000-9179.jpg
then probably not
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951133
I could use that.
Use a guide rail with a circular saw it will be a lot faster and keep things straight and in line those dremel routers are usually for cutting circles or atleast what I've done with them.
https://linustechtips.com/topic/444027-rotary-saw/#findComment-5951147
