Where do i plug these in? Power led + and power led -
with your front panel headers
MOBO- MSI z97 gaming 5  CPU- I5 4690k   GPU- G1 Gaming gtx970  RAM- 16gb Corsair Vegeance  PSU- Corsair RM650  COOLING- Corsair H110iGT
STORAGE- AMD r7 120gb SSD / 500gb HDD  CASE- Phanteks Enthoo Luxe   Sound-  Logitech z506 / Corsair Void  Peripherals- G710, G502
https://linustechtips.com/topic/443895-help/#findComment-5949110
Here
You can use the Motherboard manual for reference.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/443895-help/#findComment-5949129
And RESET SW HD AUDIO POWER SW
with your front panel headers as well.
what mobo do you have?  it should be labeled on it, if not, you can find it in the manual im sure.
https://linustechtips.com/topic/443895-help/#findComment-5949161
Jfp? Does that ring any Bells?
seriously though, you are on this website, so clearly you have internet, therefore you have access to google.
it took me 10 seconds to find this
https://linustechtips.com/topic/443895-help/#findComment-5949206
We aren't chinese over seas workers you know -_- I always search and trouble shoot before I ask the forums otherwise it's spam
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/443895-help/#findComment-5949227
@SZEM (welcome to the forums and dont forget to follow your threads so you know when people respond to them!)
if its not directly labeled on your motherboard, it will be labeled properly in the manual that came with it.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/443895-help/#findComment-5949291
