Applied new thermal paste to my CPU because I was getting very bad temps. The new paste I applied was arctic silver 5 and Im still getting extremely high temperatures... what can I do :c
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/443883-h100i-temps/
RMA it. I know this isn't the first time this happened to you
I shouldn't have to RMA it... this is the first time I actually applied new paste..
https://linustechtips.com/topic/443883-h100i-temps/#findComment-5948960
All cores the same temp?
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/443883-h100i-temps/#findComment-5948963
No they vary
https://linustechtips.com/topic/443883-h100i-temps/#findComment-5948997
No they vary
10+ degrees C?
https://linustechtips.com/topic/443883-h100i-temps/#findComment-5949011
10+ degrees C?
From core 1-4 they vary maximum 8-10
https://linustechtips.com/topic/443883-h100i-temps/#findComment-5949024
If 10 or more it might be the thermal paste on the crystal itself has dried out. If that happened no matter how fresh your thermal paste is with out deliding it won't change anything. Not sure if your cpu can be delided as some are soldered and the soldered don't have this problem normally. As long as the temperature difference doesn't go over 10C safe to say deliding is not yet required
https://linustechtips.com/topic/443883-h100i-temps/#findComment-5949121
then why are you tell us what your temps are
Hits around 80 degrees max but constanly jumps up and down
https://linustechtips.com/topic/443883-h100i-temps/#findComment-5949181
