ow should I place my fans?
Where to make it a intake and how to make it a intake? Thanks.
My build : http://uk.pcpartpicker.com/p/Ck8VkL
[spoiler spoiler=Crimson Skyline]  My build: http://uk.pcpartpicker.com/p/Ck8VkL | I5-6600K | Hyper 212 Evo | Asus Z170 Pro Gaming + ROG Front Base | Axevir Core Series Red 2X8 2400 | Sandisk SSD Plus 240 GB | Western Digital 1TB Blue | MSI R9 390 | Corsair 760T | Corsair 850 RMI | Dell U2515H IPS | Hyper X II Cloud Red | Corsair K95 RGB | Logitech G602 |
[spoiler spoiler=Laptop] I7 3232QM | Nvidia GT635M | 17.6" TN | 1TB HD | 6GB RAM
https://linustechtips.com/topic/443770-fan-orientation/
depends a bit on your case and the rest of your components. but in your typical tower setup you should have intakes at the front (2 fans preferably) and exhaust at the back (1 fan) or maybe even an additional top fan.
It's recommended to have more intake than exhaust in order to keep a positive static pressure iside your case, it keeps dust out of your PC that would otherwise just fall inside through little rivets.
You can determine which way the air flows on your fans by looking at its both sides. the one with the frame is usually the exhaust side and the one with the blade is the intake side. Jsut mount the fans in the case accordingly.
who cares...
https://linustechtips.com/topic/443770-fan-orientation/#findComment-5947474
https://linustechtips.com/topic/443770-fan-orientation/#findComment-5947479
Thanks KamiKatze!
https://linustechtips.com/topic/443770-fan-orientation/#findComment-5947488
What I would do is put two Static Pressure fans 120mm fans up the top out taking air. 1 120mm fan out taking air in the back and airflow fan. Put 1 140mm fan in the front in taking air (Air flow fan) and put another fan at the bottom of the case 120mm fan (Airflow) intaking air
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/443770-fan-orientation/#findComment-5947504
Alright, I'll try that ; thanks
https://linustechtips.com/topic/443770-fan-orientation/#findComment-5947518
For every build I've ever done I always made sure I have positive air pressure. More fans for intake than exhaust. Make sure you filter all intake fans.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/443770-fan-orientation/#findComment-5947530
