Need Help With Wireless Connection Settings.
I was watching this tutorial
to use my laptop as a router for my desktop until I can afford a long enough ethernet cable to reach all the way back into my room. but at 1:26 of the video I dont see the "Sharing tab". I think I may have broke it or did something wrong, I was watching other tutorials before that told me to do stuff different, so what I am wondering is their anyway I can bring that "sharing" tab back?
https://linustechtips.com/topic/44364-need-help-with-wireless-connection-settings/
whats your OS?
Window 7 Home Premium.
  1. Start Orb > Computer > right-click and choose Manage
  2. Double click "Services and Applications"
Double click "Services"
Scroll down to "Internet Connection Sharing" and double-click on it
On the "General" tab, set the Startup Type to "Automatic"
Click "Apply"
Click the "Recovery" tab
Click the "Subsequent Failures" button and select "Restart the Service"
Ensure that "Restart service after" is set to 0 minutes
OK out and close Computer Management
Check the Properties of your Wireless Connection
01110100 01101000 01100101 00100000 01110001 01110101 01101001 01100101 01110100 01100101 01110010 00100000 01111001 01101111 01110101 00100000 01100010 01100101 01100011 01101111 01101101 01100101 00101100 00100000 01110100 01101000 01100101 00100000 01101101 01101111 01110010 01100101 00100000 01111001 01101111 01110101 00100000 01100001 01110010 01100101 00100000 01100001 01100010 01101100 01100101 00100000 01110100 01101111 00100000 01101000 01100101 01100001 01110010
  3. Double click "Services"
  4. Scroll down to "Internet Connection Sharing" and double-click on it
  5. On the "General" tab, set the Startup Type to "Automatic"
  6. Click "Apply"
  7. Click the "Recovery" tab
  8. Click the "Subsequent Failures" button and select "Restart the Service"
  9. Ensure that "Restart service after" is set to 0 minutes
  10. OK out and close Computer Management
  11. Check the Properties of your Wireless Connection
Another website told me to do the exact same thing and it did nothing.
Probably because it's straight out of most any Window's Configuration Certification.
I've never done it this way, but you could try this:  http://www.addictivetips.com/windows-tips/simple-windows-7-file-sharing-step-by-step-procedure/
Did you get a chance to give that a shot?  I'm curious as to what your issue was.
