Project%20Outlaw%20Banner_zpse4zrsiyh.pn
 I will be doing a permanent dedicated SFF PC build for LAN events. During my last trip to QuakeCon I had a bad experience when it comes to traveling with a mid tower while attempting to travel via Amtrak, it seems that no electronic items can be checked in :huh: . But can be used as carry on if size permits, hence this build log. My next two LAN events will require travel (one in Indiana and the second PDXLAN at Oregon). Even though I may drive to both there's the possibility that I may choose to fly and take my build as a carry on when I do.
Since I am a US Army Vet and decided to start getting involved with Operation Supply Drop I chose to do a military themed build. The case I will be using is Fractal Design's Node 304 in black, but will paint an OD Green. I intent to cut in a window on top panel, replace front panel and its I/O, add case feet and a carrying handle. I'll edit and add custom parts from MNPCTECH with links below. Thanks to Bill Owen for sponsoring me with parts for this mod (see links and pictures below).
I will post updates as build progresses. In the meantime it's time to break case down.
Specs:
  • Fractal Design Node 304 Mini-ITX PC case, black
  • MSI Z97I AC Mini-ITX LGA 1150 Motherboard
  • Intel i5 4690k CPU
  • 8GB 9 2 x 4GB) Kingston Hyper Beast DDR3 2400MHz RAM
  • Two 500GB ea. Samsung 850 EVO SSDs
  • Sapphire Radeon R9 285 ITX 2GB GPU (temporary)
  • EVGA SuperNOVA 650 GS Fully Modular PSU (getting next month)
  • Four Noctua NF-B9 redux 1600, SSO Bearing Fan 92mm (getting next month)
  • One Noctua NF-P14s redux-1500 PWM, SSO Bearing Fan 140mm (getting next month)
  • Cooler Master Hyper D92, CPU cooler (getting net month)
Note will either use two 92mm 0r two 80mm case fans for custom front panel, will know more as I start mod.
img_20150902_160038641_21085392332_o_zps
img_20150901_143956897_20472354374_o_zps
img_20150902_134030551_20473900163_o_zps
img_20150902_134048880_20472353004_o_zps
img_20150902_134059649_21102672581_o_zps
img_20150902_134111624_21068783826_o_zps
Removed rubber "case feet" and discovered screws underneath. Seems like there's a bottom plastic like tray that can be removed as well.
img_20150902_144349713_20908174819_o_zps
I chose to remove this bottom "tray" for better installation of custom case feet.
img_20150902_144534215_20908174579_o_zps
This is the bottom plastic like tray removed.
img_20150902_144540211_20906891980_o_zps
Removed two front 92mm case fans, will cut out these fan mounts for custom front panel and replace with another 92mm or 80mm fans.
img_20150902_144616350_20472353834_o_zps
Removed built in fan speed controller since I will not use.
img_20150902_144621123_20472353694_o_zps
Removed PSU bracket and top bar which supports the three hard drive trays which I will not use either.
img_20150902_160130447_21085392202_o_zps
Removed the left side GPU filter.
img_20150902_160253575_21085392242_o_zps
Removed the right side PSU filter.
img_20150902_160302969_20472839284_o_zps
Everything has been broken down and removed, will take measurements and prepare to start cutting and drilling before painting.
img_20150902_1612022921_21085560522_o_zp
PSU bracket and internal PSU cable in one easy to find place/bag.
img_20150902_1612108701_20907523010_o_zp
Mnpctech PC & Case Mod Product Links
Lamptron Bulgin Mounting Plate, 22mm by 22mm, Black by Mnpctech, http://mnpctech.com/bulgin-modmytoys-computer-pc-power-reset-switch-mounting-plates-vandal-anti-resitant-lamptron/22mm-22mm-switch-plate/lamptron-bulgin-mounting-plate-22mm-by-22mm-black.html
22mm_switch_plate_mounting_bulgin_vandal
anodized_red_blue_green_gold_22mm_pc_mod
Mnpctech Red & Green Vandal Resistant PC Power Switch, 22mm, http://mnpctech.com/case-mods-gaming-pc-liquid-modding-custom-computer-mnpctech-overclock-cooling-fan-grills/switches-toggle-pc-computer-power-reset/vandal-resistant-pc-power-switch-22mm-clone.html
red_anodized_bulgin_lamptron_mod_toy_van
green_anodized_bulgin_lamptron_mod_toy_v
Mnpctech Mini ITX Custom Machined Aluminum PC Case Feet, http://mnpctech.com/pc-computer-stereo-desktop-case-feet/mini-itx-pc-case-feet.html
billet_computer_stereo_mini_pc_case_feet
Gaming or LAN PC Carry Handles are made from solid 3/8" diameter Stainless Steel, http://mnpctech.com/pc-case-lan-party-gaming-carry-top-server-tower-handles/pc-bar-handles.html
gaming_pc_lan_party_case_carry_handles_m
https://linustechtips.com/topic/443206-project-outlaw/
OD Green 304 sounds good, are you doing it a just a flat green or are you going to weather it and make it look all military and stuff?
Aim high, hit low. - Oliver Guy (Me)
If you can't make it good, at least make it look good. - Bill Gates
Only two things are infinite, the universe and human stupidity, and im not sure about the former. - Albert Einstein
https://linustechtips.com/topic/443206-project-outlaw/#findComment-5942295
  • 2 months later...
Phew, it has been very hectic lately and drove from Fort Smith, AR to Portalnd, OR for PDXLAN :huh:  Here are some updates (finally)!
Measuring for custom power and reset switches plate
Measuring for handles
Paint and added a custom top fan mount for intake
Added rubber channel
Gotta show that Munky Army pride
Placing manufacturer filters/mesh grills back
Added custom front window
Added Operation Supply Drop Patch
ATEAMGC Love
Added COD Endowment Dog Tags to keep a military and gaming theme going. Also placed US Army decal on front window panel. Hooah!
Final look and internal hardware
NocturneKittie%20on%20Instagram%20%20ldq
Please see parts list at the following link: https://pcpartpicker.com/user/NocturneKittie/saved/Tmv7YJ
Updated look during second use (LAN event). Changed case feet and handles for PDXLAN. These are from MNPCTECH as well
https://linustechtips.com/topic/443206-project-outlaw/#findComment-6583421
