maybe you can ask your brother steve jobs :P
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/443033-help/#findComment-5937532
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/443033-help/#findComment-5937546
i dont care
https://linustechtips.com/topic/443033-help/#findComment-5937549
use a stereo mix
example of a stereo mix on my soundcard
http://puu.sh/jYclj/8f8f0b530a.png
stereo mix is either called > what you hear or stereo mix, then simply select stereomix/what you hear @ skype and itl work :P ( make sure u got the volume proper set too, cheap soundcards and onboard soundcards will require 100% recording volume on stereo mixes usually , while mine is amplified im fine with 15-20% )
https://linustechtips.com/topic/443033-help/#findComment-5937561
