I really need help with my cpu fan I just bought. I tried to install it, but the back plate didn't fit into my motherboard. Is there any way to install it using the back plate already on my motherboard. How do I know if its even compatible with my motherboard. Thank you in advance for your help.
here is my pc build
http://pcpartpicker.com/p/wy8s4D
https://linustechtips.com/topic/443020-need-help-with-cpu-fan/
here is my pc build
it is compatible
you probably doing something wrong
read the directions again
https://linustechtips.com/topic/443020-need-help-with-cpu-fan/#findComment-5937412
the backplate on my motherboard is rectangular and the backplate for the fan is a square. The backplate wont fit. I attached some pics
The bracket you are trying to use is for Intel mobos. Use AMD bracket instead. And please read those instructions.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/443020-need-help-with-cpu-fan/#findComment-5941199
