Hey everyone!
So, im planning on a system upgrade but im not sure on which case to get yet...
I was considering the h440 the define r5 and the define s.
Which case would be better for me?
I need:
-good airflow and radiator support for future water cooling
-2ssd and one 3.5" hdd mount (at least)
-support for quite long gpu(s) (gigabyte 980ti for example
-preferably good cable managment options
Of you have another case to follow my white and Black color sceme, please let me know ;-) anything under 170 dollars is ok ;-)
Thanks in advance!
-Gijs
Current Build: CPU: i7-3770 GPU: Asus Strix GTX 970 Mobo: P8Z77-V LX2 RAM: 16 Gigs of random DDR3 ram Storage: WD Caviar Black 2TB drive Case: Nexus Prominent 9 Cooler: Stock intel cooler, Stock Case fans PSU: OCZ technologies 750 w PSU Monitor: 2x Philips 243V5 OS: Windows 8.1 Pro Sound: Logitech G430 Keyboard: Logitech K290 Mouse: Logitech G502 Mic: Blue yeti
https://linustechtips.com/topic/442733-best-case-for-me/
Take a look at plantecks cases
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/442733-best-case-for-me/#findComment-5933563
@Fictionvl cant get phanteks cases in my area :-/
https://linustechtips.com/topic/442733-best-case-for-me/#findComment-5933608
Oh that sucks, well the H440 has really low airflow, look at the noctis 450 it has the interior of the H440 but with a lot more air flow
https://linustechtips.com/topic/442733-best-case-for-me/#findComment-5934001
@Fictionvl I just saw the n450 on yt, ill get the white version and keep the leds off ;-) it will match nicely! Thanks a lot!
https://linustechtips.com/topic/442733-best-case-for-me/#findComment-5934023
Glad I helped :)
https://linustechtips.com/topic/442733-best-case-for-me/#findComment-5934702
