My brothers PC has the following specs - i5 3350p, GTX670 DCUII, 8gb ram, and a 650w PSU
It is built inside of a prebuilt case but we are going to get him a new case in a few weeks. Until then would you guys say it's safe to run the PC with the side panel off because the graphics card is smothered by it and creates a ton of heat even on 100% fan speed.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/442687-hot-pc/
Yeah it's safe. Make sure if you've got pets or something to watch them. My dog tried to lick my CPU fan running at max RPM. That would of been bad,
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/442687-hot-pc/#findComment-5933079
haha good thing the the side that would be exposed will not be accessible by our 2 dogs =)
If he can deal with the noise, then: Yes, sure :)
I'd say yes :) But don't throw something in it :)
 The noise wont be a problem, currently to cool things down we have an external desk fan pumping in air through the tiny circle cutouts (Thanks asus)
https://linustechtips.com/topic/442687-hot-pc/#findComment-5933099
Yeah it's fine. Just clean it more often as it will gain more dust in a shorter time.
I had to do it many years ago when I was waiting for a new computer case.
It's not a race to the bottom.
https://linustechtips.com/topic/442687-hot-pc/#findComment-5934377
