Hard drive to ssd help
Go to solution Solved by Aytex,
I have a windows installation disc that i purchased. I don't need to pirate, lol.
no. don't do that
plug your SSD in and remove your HDD
install the OS on the SSD
put the HDD back in
Format your HDD
bam your done
Hello, i am a fairly experienced person when it comes to computer systems but i have one issue. I was wondering when i purchase my ssd, if i can format both my hard drive and my ssd then install windows on my ssd while the hard drive is still inside the computer. I don't want to clone the hard drive as it has so many files that i don't need, i just want to start again. Is this possible?
Thanks
https://linustechtips.com/topic/441945-hard-drive-to-ssd-help/
Thanks
Without getting another key, I think the easiest way would be to clone your drive, then reinstall using the Windows 10 reinstall option.
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/441945-hard-drive-to-ssd-help/#findComment-5923229
no. don't do that
put the HDD back in
Format your HDD
bam your done
https://linustechtips.com/topic/441945-hard-drive-to-ssd-help/#findComment-5923230
