Hi guys,
Has anyone ever had the issue where your graphics card gets stuck in the P2 state? Even under load, my 980 ti won't switch between the P2 and P0 state.
I did manage to set my default P2 memory clock to the default P0 memory clock, which was 3505 MHz. It was originally downclocking by 200 MHz x2 and getting stuck there, even under load.
I used NVInspector, but it would be nice if the card switched to P0 when under the highest load.
If anyone has a solution to this problem, I would much appreciate it if you could help me out. Googling it didn't bring up many posts about it and the ones that did weren't too helpful.
Thanks!
EDIT: I managed to fix it by spamming NVInspector/MSI AB overclocks and continually changing the clock speeds whilst under load. Not sure why that worked, but it's fixed anyways.
Edited by Flaveless
https://linustechtips.com/topic/441556-p-state-stuck-at-p2/
