HELP Need Tiny Gaming Display (<18.5")
So I'm looking for a decent gaming monitor for under 18.5 inches.  Before you ask, no there is absolutely no way it can be any bigger.
For those of you wondering, I need to mount this monitor inside the top of a briefcase and so it needs to fit inside.
NEEDS:
-18.5" or less (including bezel it needs to fit inside an 18"x13" hole)
-VESA mount (any size will work 75mm, 100mm, etc.
-Widescreen (16:9, 16:10)
-bottom facing plugs (It will be mounted up against a flat surface and so I will need to access cables from below)
WANTS:
-1080p
-Speakers
I haven't thought of a good signature yet.
https://linustechtips.com/topic/441069-help-need-tiny-gaming-display-185/
I'm interested in why you need it that small tbh.
Could rip a display from an old laptop.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
75mm or 100mm VESA?
Needed outputs?
Any special frills? Refresh, resolution, speakers/no speakers, etc.?
EDIT: Also, please follow your topics..
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
What is people's obsession with telling others to follow their topics.
GEez.
GEez.
/me hopes this is /jk
Terribly difficult for OP to respond if he doesn't see there's something to respond to. Haven't seen him on this page since I've been here.
EDIT: But before we derail...
I'm not.
I've never followed a thread of my own. Notification spam usually.
I just check back on it frequently (varies depending on how important it is)
I am mounting the display in the top of a briefcase, so it needs to be tiny enough to fit inside.  I don't really have an old laptop to rip from, but that sounds like a decent idea.  Any ideas of where to find one?
a lot of smaller displays are older and have large bezels. is it a screen size restraint or a overall size restraint?
It is an overall size restraint and yea after looking around I have started to notice that.  Alot of them are in more square aspect ratios as well as apposed to the more common 16:9 or 16:10 these days.
you can just go to amazon/newegg and sort by screen size
Have tried this, none of the monitors seem too good.  Thanks for the suggestion tho.
75mm or 100mm VESA?
Needed outputs?
100mm vs 75mm doesn't matter to me.  I just need it to have screw holes in the back so that I can mount it myself.  I would like it to be 1080p if possible but I realize that might be hard.  Speakers would be nice, although not a necessity.  Don't care too much about refresh rate as long is it is above 60.
Thanks for the link although I don't think I will be using any of those.  I am looking for something widescreen.  My fault for not including that info in the post.
We're gonna need a little more info. Why under 18.5? What features are important to you? Which display port?
I have updated the initial post to include this stuff as well:
NEEDS:
WANTS:
-1080p
-Speakers
Any more information you all think I need to include?
NEEDS:
WANTS:
-1080p
-Speakers
Replying on mobile, so I don't have my link anymore. Newegg search came up with 0 1080p displays last night. Go to Newegg > find monitors > search for 18.5". That's the link I would have given you. I'll try to get one off mobile really quick. Be back...
NEEDS:
WANTS:
-1080p
-Speakers
unfortunately there is no 1080p screen of that size
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007617%20600338088%20600520363%20600030608%20600531842%20600531840%20600030609%20600030641%20600030636%20600030658%20600030610%20600030612%20600030643%20600030659%20600030155%20600338085%20600287844%20600287843
Rigs I've Built
Ok thanks
hmmm. Ok thanks.  Either of you have an idea of what to use in this case?  Maybe a laptop monitor?
