Even if the cooler would weigh the same as the one on the video card, the CPU cooler has increased weight density and may cause the PCB to bow. Why would you do that anyways? It's just a 650. Not much performance to be had in the first place.
https://linustechtips.com/topic/440833-graphics-card-cooler/#findComment-5908600
would do it - some guy did that even on youtube - let me search the vid.
u may need to modify the mounting mechanism or like linus use zipties. THIS card will  run at room temp under load;)
EDIT:
1:
2.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/440833-graphics-card-cooler/#findComment-5908602
