CPU: Intel Core i7 6700K.
COOLER: EK Predator 240 AIO Liquid CPU Cooler.
GPU: ASUS GeForce GTX 980 Ti Strix 6GB.
GPU: ASUS GeFroce GTX 980 Ti Strix 6GB.
HDD: Western Digital WD Black 4TB.
SSD: Samsung 850 Pro Series 500GB SSD.
RAM: G.Skill Ripjaws V 16GB 3200MHz DDR4.
PSU: EVGA SuperNOVA Platinum 1200W.
DVD: ASUS DVD Writer.
MOBO: ASUS Maximus VIII Hero Motherboard.
CASE: Fracal Design Define R5 Black Pearl.
Monitor: AOC 28in 4K UHD Widescreen Monitor.
Fans: Corsair Air Series AF120 Performance Edition.
So What do you think of the build.
My Thoughts:
1. Getting a Corsair Power Supply so I can use Cable Mod for Red and Black Cables.
2. Getting Red LED Strips.
Btw I do have steam so if anyone wants to add me on steam go for it!
https://linustechtips.com/topic/440358-my-build-thoughts/
If price is not an issue, which it appears to not be, then yes an AX1200i will look dank with cable mod cables.
Also please post a build log in the build log category. I'd like to see this come together.
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
https://linustechtips.com/topic/440358-my-build-thoughts/#findComment-5903247
My Thoughts:
for how much you're paying for that (obviously overpriced) motherboard and cpu you can get an 5820k and a x99 motherboard which will outperform the skylake i7 by quite a margin
also, i'd get a normal 4tb hdd like a wd blue or any other seagate. it's not like you'd feel the performance improvement and i heard that the black drives are quite noisy
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/440358-my-build-thoughts/#findComment-5903274
Do you really think the 5820k because im going to be doing video Editing and Gaming. and just Normal use..
More cores will help you if you plan on editing. Also the 5820k has more lanes and it gets rid of any bottleneck for your 2 980ti's.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/440358-my-build-thoughts/#findComment-5903323
What about the 5930k
Even better.
https://linustechtips.com/topic/440358-my-build-thoughts/#findComment-5903372
https://linustechtips.com/topic/440358-my-build-thoughts/#findComment-5903560
But I would like a 6700k because the performance is great. and I have seen the benchmarks on the 6700k and the 5820k and the 6700k wins. but idk about my GPU's.
The 5820k should outperform the 6700k in most computing benchmarks, but the 6700k has better single core performance so it is probably better in  gaming. But for rendering and editing the 5820k almost always takes the cake. GPUs are probably the best now unless you wanna spend 350 more for a titan x.
https://linustechtips.com/topic/440358-my-build-thoughts/#findComment-5915663
