So its been a while since I have done a huge upgrade on my PC, but it is much needed.
Current Part List: Pc Part Picker
Originally I was looking into just upgrading my CPU but the only really good option was an
Intel Core i7-3770K wich is priced at 480$ before tax and thought that that would be a stupid investment now that 1155 is an out of date chipset.
Then I began my search for better Cpu's for what I am trying to acomplish (Gaming / Video Streaming) and stumbled upon the
Intel Core i7 4790k which is priced at 280$ and leave me some room to upgrade my motherboard.
Here comes the problem. I need help deciding on a motherboard to get and i would like it to be future proof.
I am a fan of Asus motherboards and would like to stick with it any suggestions on motherboards?
https://linustechtips.com/topic/440142-help-pc-upgrade/
Go on fleabay/craigslist and see if you can find a 2500K or i5-3570K. If you are only gaming ditch the i7.
Grab a good CPU cooler and profit for relatively cheap. i5-2500Ks can be had for around £50/$75 in the UK at least.
You should be able to get that and a cooler for maybe $150-$200 and itll keep you happy for a while.
EDIT: More ram also won't hurt.
If you are going to go i7 and a new platform, then go 5820K...
https://linustechtips.com/topic/440142-help-pc-upgrade/#findComment-5900448
I personally have this motherboard:http://pcpartpicker.com/part/asus-motherboard-z97e
its great and has good reviews your part list has 4gb ram i suggest u upgrade to at least 8gb ram
https://linustechtips.com/topic/440142-help-pc-upgrade/#findComment-5900509
That may not be in his budget to get the 5820k ... with the x99 platform he will have to purchase ddr4 ram
https://linustechtips.com/topic/440142-help-pc-upgrade/#findComment-5900519
