Installation Problem
Go to solution Solved by kameshss,
Malwarebytes ran the scan and found nothing
Clean Install the Windows dude.
I can't seem to find any possible reason for the problem.
I have a problem with my laptop were I can not install or update any of my programs.  I was downloading java from ninite.com and when it was installing i got a message saying,
"Waiting for another installation to finish... (MSI)"
It has been doing this for the past two days and does not look like it will go away on its own i cant update anything or uninstall anything.
I am running an Asus Zenbook UX305 with Windows 10
Any help would awesome.
Corsair 350d, Asus Gryphon Z87, Intel i5 4670k 4.5 GHz, Corsair H100i, Corsair Vengence 16gb 1600 MHz,
AMD Radeon 260x, Corsair CX600, OCZ Vetex 450 128gb, Seagate 2 TB
https://linustechtips.com/topic/440032-installation-problem/
Restart!
I have restarted my computer 10 times already.
The problem is still there
https://linustechtips.com/topic/440032-installation-problem/#findComment-5898935
Whats the full Error?
Im not sure that it is an error it is just a message saying that it is "waiting for another installation to finish... (MSI)"
That is exactly what it says
https://linustechtips.com/topic/440032-installation-problem/#findComment-5898953
Have you searched through Task manager for un usual programs being run?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/440032-installation-problem/#findComment-5898954
are there any oddities in startup applications?
No nothing out of the ordinary, I have ran a virus scan several times already
https://linustechtips.com/topic/440032-installation-problem/#findComment-5898964
Before installing Java
Go to task manager
Check if there is any "Windows Installer" process running. If so end it.
Then try to install. It should work.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/440032-installation-problem/#findComment-5898969
yes and nothing that is takeing up more cpu, ram, or disk than anything else
https://linustechtips.com/topic/440032-installation-problem/#findComment-5898971
Go to task manager
I tried that but it just comes back as soon as I end the task
https://linustechtips.com/topic/440032-installation-problem/#findComment-5898980
Try running ADWCleaner S/W and Malwarebytes.
They can eliminate somethings that are undetected by Anti-Virus SW.
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899050
Do i have to download and install those programs because I cant install anything.
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899062
ADWCleaner is a portable program.
You have to install the Malwarebytes. But it doesn't use Windows Installer. So try.
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899087
I was able to get ADWCleaner, ran it and the problem is still there
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899129
Malwarebytes?
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899147
currently running scan
Post back with results.
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899185
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899261
Thanks for the help i think that i will just have to do that.
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899264
Yeah!
Get rid out of all probs! :)
https://linustechtips.com/topic/440032-installation-problem/#findComment-5899292
