HI i have
i5 4690k
AMD 7970 reference design
8 gb ram FURY
1hdd WD green
120gb ssd samsung 850 evo
So i play at 1440p at every game today i try to recording gta 5 i set OBS at 1440p and when i play there is a complete lag why ?
i'm not an expert
What hardware i have to change ??
https://linustechtips.com/topic/439795-problem-when-i-rec/
well, running 1440p on a 7970 is already pushing it, not to mention recording at the same time. I'd recommend getting a better gpu (980/ti), or toning down to 1080p and recording like that.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/439795-problem-when-i-rec/#findComment-5896084
HI i have
i5 4690k
8 gb ram FURY
1hdd WD green
i'm not an expert
That rig would be better for a 1080p setup.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/439795-problem-when-i-rec/#findComment-5896087
Go 1080p.
It'll be better
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439795-problem-when-i-rec/#findComment-5896088
Go 1080p.
It'll be better
if i buy a r9 290x ????
the problem isn't the cpu ?????
https://linustechtips.com/topic/439795-problem-when-i-rec/#findComment-5896099
Yep!
Better.
https://linustechtips.com/topic/439795-problem-when-i-rec/#findComment-5896105
Yep!
Better.
better, but I'd be looking at like a 980 or something if you're really set on recording/playing at 1080p at the same time.
https://linustechtips.com/topic/439795-problem-when-i-rec/#findComment-5896122
