Yes, it's possible. What resolution is said monitor, though?
Just set the resolution to 1920x1080 in Windows?
So it's 1680x 1050p and I want to record 1080p of course
Also I can't set actual screen resolution to 1080p
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/439681-resolution-help/#findComment-5896852
Dammit.
Uh... I guess you're stuck at like 1600x900 or 720p for recording then.
https://linustechtips.com/topic/439681-resolution-help/#findComment-5897091
