The case you want is quite expensive, here is an example build tho
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£139.99 @ Amazon UK)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  (£48.12 @ CCL Computers)
Memory: Kingston Savage 8GB (2 x 4GB) DDR3-1600 Memory  (£35.57 @ CCL Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£38.70 @ Amazon UK)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  (£253.99 @ Aria PC)
Case: be quiet! Silent Base 800 ATX Mid Tower Case  (£83.80 @ Scan.co.uk)
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£62.48 @ Novatech)
Total: £662.65
Generated by PCPartPicker 2015-08-28 12:11 BST+0100
The site has changed....
https://linustechtips.com/topic/439107-quiet-build/#findComment-5887646
it is basicly the i7 4770k but without graphics and yes with HT but hyperthreading makes it somewhat more expensive then the one jimakos has
Total: £662.65
that is £50 over budget
https://linustechtips.com/topic/439107-quiet-build/#findComment-5887813
http://skinflint.co.uk/eu/?cat=WL-578207&wlkey=e6b1f06343bee74a48c2673cb73378a5
thats what ive put together and i know it is a little over budget but im looking in it right now
also you can choose some parts
Change the psu pls, dont cheap out at the psu, it can be dangerous, it is like the heart of the pc.
Get a Seasonic/XFX/EVGA G2-B2/Antec/SuperFlower/SilverStone psu.
https://linustechtips.com/topic/439107-quiet-build/#findComment-5887876
i wasnt actually trying to cheap out on it i have good experiences with lc power but better safe thant sorry ill change it
https://linustechtips.com/topic/439107-quiet-build/#findComment-5887897
