Get the a Noctua or some inaudible air cooler, set fans to 400 rpm in BIOS.
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887238
depends how much you are willing to spend, and which you like the look of.
but if you do get a high-end noctua/cryorig/bequiet air cooler, or the H100i GTX then definitely consider overclocking.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887239
Get one of those Air coolers if you're not doing much of an Overclock (Just spray paint the Noctua fans or something, or just wait for the LTT themed fans) or get the H100i GTX if you're doing a serious overclock
Hey everyone! I am doing a new build soon and it would be great to get some feed back! I don't know if i should get the
Corsair H100i GTX
212 EVO
or a Noctua cooler
I honestly dont think i will even overclock either. my build so far >>> http://pcpartpicker.com/p/zhRK99
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887255
But wont the Noctua hang on the cpu and ruin it over time?
the cooler isn't actually attached to the CPU it's attached and held in place by the motherboard. so it's perfectly safe. otherwise people wouldn't get the monstrous dual-tower coolers.
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887276
212 evo is the King of budget cooler.
Noctuas are King of all air coolers imo.
DARK ROCK PRO 3 by bequiet is also similar to Noctuas in performances.
I'd select NZXT Kraken X61 instead of H100i GTX.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887311
Dark rock pro is really hard to install :c
Magical Pineapples
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887392
Follow the instructions given by manual.
It's not that hard.
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887413
It's not that hard.
Yea.. tried you need a really small fingers to do it.
Magical Pineapples
https://linustechtips.com/topic/439091-what-cooler/#findComment-5887910
