Maybe the system still tries to output the video signal via the integrated GPU? Try to deactivate the onboard GPU in the BIOS and set the card in PCI Slot X to be the main output one (at least with gigabyte boards this is possible, will be similar with other manufacturers).
https://linustechtips.com/topic/439056-gpumobo-problems/#findComment-5886810
Cant find that setting .
https://linustechtips.com/topic/439056-gpumobo-problems/#findComment-5888357
In my bios it's named "initial video output", look for something similar.
Also if you boot using integrated graphics can you see the dedicated GPU in the device manager?
If I put my graphics card in the screen wont notice anything it stays black, and in the bios i can change pci gen x to 1 2 3
https://linustechtips.com/topic/439056-gpumobo-problems/#findComment-5888945
