Should be able to overclock. Do you want to OC through your BIOS, or through 3rd party software?
Also, quickly, what Heatsink and fan are you using to cool your CPU?
Intel LC good enough?
Yeah it should do well, it's on par with air coolers. People with air coolers can usually get decent overclocks :)
https://linustechtips.com/topic/439-noob-oc-help/#findComment-5398
I bought the intel LC 3 weeks ago.. I think overclocking throught the BIOS is better?..
That should be alright, just keep an eye on temperatures after OCing. With your mobo I'd do it through the BIOS. Make sure your overclock is stable though, do at least a 24H burn in test with Prime 95 or a similar package.
https://linustechtips.com/topic/439-noob-oc-help/#findComment-5403
Btw i have never OCed.. So i have searched on how to do it and i have find some articles that go through step by step, but i was just wondering if that i could just put the last multiplayers and voltages and then test for stability( the final freq. Was like 3.8ghz) do you think that it's a good idea to do this?
https://linustechtips.com/topic/439-noob-oc-help/#findComment-5481
